| For installing pistons, crank, connecting rods, ect.. (all the internals for a block) ((after a fresh rebuild)) What I need to know are: The order in which you install each part inside the block also. How many pounds of torque to apply to each bolt? What order do you tighten each bolt? I have already found this and will be using it when i get to that stage but i couldn't find any write ups on how to assemble the block. [ http://www.twinturbo.net/nissan/300zx/tech/rebuild/rebuild.aspx ] (^this is perfect and i will be using it for sure but i need the same thing but about the top end) I will buy a book if someone knows where to find one new or used it does not matter(I have searched all over). Price does not matter. What matters is that it is very detailed and is step by step (the FSM is not detailed enough it doesn't even talk about reassembly)
Thanks in advance for any help Mark,
------------------------------------------------------------ Nissan prayer, Our Father who art in Nissan hallowed be thy name. Thy SR come, the boost will be done, in Silvia as it is in Skyline and Z cars. Give us this day our daily kill, and forgive us our bad launches as we forgive hondas who launch against us. Lead us not into traffic court but deliver us from the 5-0, for thine is the turbo, the pistons and the LSD forever- AMEN |
